How to remove AC clutch coil on a 1999 P71 Crown Vic
Old May 27, 2011 | 01:55 PM
Mith's Avatar
Default How to remove AC clutch coil on a 1999 P71 Crown Vic
Forgive me if I failed to properly search and this is covered elsewhere (I did search! )
I have a 99 Crown vic (P71), the AC clutch is bad from excessive idle while it was in active service. Picked up a clutch replacement set for it, and rented the "proper" tools (which were of no help at all...) The hub/pulley/bearing assembly came off relatively easily once I got the *bleeping* snap ring out and after some spray on derust/bolt lube. However, the coil is on quite solidly, as far as I can tell it does not use a snap ring so I am guessing it is friction-fit. However the rented toolset does not have anything it it that would be able to help. I'd leave the coil on but it is slightly the wrong size for the new hub assembly.
Old May 27, 2011 | 05:36 PM
way2old's Avatar
We use a thin chisel and tap it around the perimeter of the coil. Just take your time and it will come off. Ford's manual says to use a 2 jaw outside puller.
bedbunker
Mar 24, 2023 04:27 AM
raleighnccrownvic
Jan 10, 2012 08:18 PM
daddy2595
May 4, 2009 12:47 PM
JonnyP71
Dec 29, 2006 11:35 PM
ten8goa
Jul 31, 2006 11:37 PM
