what transmissions will fit my car?
Old Jan 26, 2011 | 12:42 PM
summerson1's Avatar
Default what transmissions will fit my car?
ok so my transmission is toast and im not sure exactly what transmission years will fit my car. mine is a 95 grand marquis
Old Jan 26, 2011 | 01:03 PM
summerson1's Avatar
i found a transmission but its out of a 98 will it fit?
Old Jan 26, 2011 | 06:40 PM
way2old's Avatar
Usually a 95--96--or 97 will work. I think the 98 has a different wiring and solenoid package that is controlled by a different parameter than the 95.
Old Jan 26, 2011 | 08:22 PM
summerson1's Avatar
will i be able to switch it to the older wiring package?
Old Jan 27, 2011 | 06:02 PM
way2old's Avatar
I do not think so. The solenoids and wiring connectors are completely different. There are more wines in the 98 connector than the one in the 95. The 95 through 97 have all the same wiring. If you try, you will have to replace all the internal solenoids and wiring. So you may have some bad parts also thet you are trying to install in the 98. I guess if you want to make it work and are willing to do a lot of work, I guess it is possible although it is not probable.
Old Jan 28, 2011 | 01:20 AM
summerson1's Avatar
aha! i found out thanks to the guys at crownvic.com that i can use the transmission all i have to do is repin the connectors on my vehicles wiring harness. a few people there have done it and all i need is some basic wiring skills and a diagram showing what wire goes where which i found on google
powerstroke99
Dec 14, 2007 12:01 PM
rockiesgirl
Feb 10, 2007 04:43 PM
powerstroke99
Oct 18, 2006 08:38 AM
Sanguinius
Dec 22, 2005 04:55 AM
rwbatten
Feb 28, 2005 07:20 PM
