1984 4.9 liter Engine Oil Amount & Level
Old Aug 11, 2019 | 06:25 PM
John Drazba's Avatar
Default 1984 4.9 liter Engine Oil Amount & Level
Hello folks. I have what seems like an obvious question. I recently changed the oil in my 1984 E150 4.9 liter, six cylinder engine. The 1984 Ford Do It Yourself Service Guide states that it should take 5 quarts plus 1 quart of oil for the filter for a total of 6 quarts. I did this, buttoned everything up, ran the engine, checked for leaks. The next morning I checked the oil level and it was in the middle of the "safe" zone (see picture).
However, the 1984 Ford Truck Pre-Delivery, Lubrication, & Maintenance Manual states that the oil level should be between the "SAFE" and "O" marking on the dipstick. The "O" marking is about one quart higher, making the oil change then 6 quarts plus 1 quart for the filter for a total of 7 quarts.
Which is correct? Thank you.
Old Aug 11, 2019 | 06:43 PM
Providing this is the original and correct dipstick, I would go by what the dipstick shows.
Remember; it takes a while for all the oil to drain back down to the pan , so a 5-10 minute wait or longer might just show a level closer to the full mark.
Old Aug 11, 2019 | 08:03 PM
Hanky,
Thanks for the response. The dipstick has both the "SAFE" zone and "O" markings on it. I will try and find a better picture to post here. If you look at the rough picture I originally posted, you can see both markings.
I waited overnight before checking the oil after the initial 6 quart oil change (5 plus 1 for the filter).
lyleb
Oct 14, 2018 07:40 PM
niallsdexta
Jan 14, 2013 04:17 AM
andipoll
Feb 16, 2009 11:21 PM
maceman07
Jul 23, 2007 07:00 PM
