1993 e 150
Old Nov 12, 2012 | 01:51 PM
Raymond J. Alaounis's Avatar
Default 1993 e 150
it is running poor at idle and shouts off tried the air control valve do not know how to test the electrical. my son says it is the fuel pump. any help would be good thanks.
Old Nov 12, 2012 | 03:02 PM
Welcome to the site Raymond..
Any check engine light on? Also,, if you just open the throttle 'slightly' (just enough to be off idle) does it correct and run fine? If it were the fuel pump, it wouldn't have any top end performance. Generally fuel delivery/volume/filter etc. problems affect more of the cruise speeds.. EGR, TPS, or vacuum leaks can affect idle stabilty as well..
Old Nov 12, 2012 | 08:27 PM
cappo's Avatar
my '99 does the same thing occasionally. I have to disconnect the battery for a couple minutes then re-connect and then she runs fine. only does it a maybe 2-3 times per year
Old Nov 13, 2012 | 05:05 AM
thanks after i posted this i went out and started messing with it i unpluged the map sensor and it ran fine i think that might be the problem.
ford09
Sep 1, 2012 10:02 PM
joachim1340
Jul 11, 2012 09:29 AM
willytorres1
Jan 15, 2012 08:35 PM
deathbymonkey
Nov 23, 2011 01:36 PM
wtf2kid
Oct 11, 2011 02:35 PM
