1994 Ford E-150 Throttle Position Sensor Location
Old Jan 4, 2020 | 02:55 PM
AutoMechanic's Avatar
Default 1994 Ford E-150 Throttle Position Sensor Location
I’m wanting to know if a 1994 E-150 has a Throttle Position Sensor. It has the 5.8 V8. I found the Idle Air Control Valve and throttle body but can’t find the sensor. It has a very high idle when you start it up and it doesn’t go away. I tried cleaning the throttle body and that didn’t work.
Old Jan 4, 2020 | 05:45 PM
It does have a TPS on the backside of the throttle body.
If I might , I would suggest you look for a pretty good size vacuum leak. The system is most likely sensing a lean mixture and is adding fuel to compensate resulting in a high idle RPM.
A coolant temp sensor may not be telling the truth and the computer thinks , based on that info, that the engine is cold and therefore needs extra fuel and higher RPM .
So you see, there could be a few reasons for a high idle speed and not necessarily a faulty TPS.
Old Jan 4, 2020 | 08:36 PM
Thank you I will check on those too to make sure
grumpyone
Feb 8, 2020 09:21 PM
Txbrandingman
Jul 17, 2019 12:06 PM
bradleyheathhays
Dec 7, 2017 08:52 PM
festy90
May 29, 2009 09:23 AM
bugwood
Sep 10, 2008 06:58 PM
