Throttle Position Sensor
Old Sep 10, 2008 | 04:25 PM
bugwood's Avatar
Default Throttle Position Sensor
My F250, 5.4 will not idle right. Sometimes it idles around 1500, sometimes it will not idle at all. If I use the clutch to slow down rpm will drop to 500 and sometimes the engine dies. Will the throttle position sensor cause this problem and if so where is it located?
Old Sep 10, 2008 | 06:58 PM
Default RE: Throttle Position Sensor
Check the IAC (idle air contol motor) behind the throttle body.. Try and crack open the throttle 'very' slightly,does the engine/idle smooth? Check the PCV and hose as well,and attachment to the back of the intake.. Any check engine light?
Doyle
Aug 21, 2017 06:02 AM
Ejectr
Aug 26, 2009 08:58 AM
camperman
Apr 24, 2008 03:21 PM
Mals
Mar 17, 2008 12:56 PM
qcarver
Sep 30, 2007 11:34 AM
