1999 E 150 won't start
Old Mar 12, 2013 | 09:01 PM
  #41
Dwayne Gessner's Avatar
I found the short. It was about a foot back from the solenoid on the canister. The harness was rubbing on a body mount and the red wire was completely cut through. Soldered, taped and shrink tubed the splice, drove all day so far so good! BTW I pulled CB out and replaced it with the fuse. the only thin I noticed was the van seems to idle lower and a little rough. I did a full tune up about 1500 miles ago and it was running great before this.
Old Mar 13, 2013 | 03:53 AM
  #42
Glad you found and corrected the problem. Since you corrected the problem you might remove a battery cable one more time to remove the keep alive memory in the PCM and allow it to readjust itself after you drive it a few times. It should improve each time you take it out and drive it. As you know by this time persistence pays.
mitch0894
Nov 14, 2012 04:34 PM
zthatzmanz28
Mar 13, 2012 03:17 AM
peterjb
Sep 24, 2011 06:22 PM
Seengs
Mar 31, 2008 05:54 PM
Frustrated
Jun 13, 2005 12:49 PM
