2003 E-350 cutaway misfire pinging blowing lots of smoke
Old Jun 10, 2024 | 04:32 PM
Kinda93cobra's Avatar
Default 2003 E-350 cutaway misfire pinging blowing lots of smoke
Misfire pinging blowing lots of smoke no power of course
Drive with part throttle for couple miles then it's ok but still has slight pinging under throttle no smoke
Only code lean bank 1
Old Jun 10, 2024 | 08:07 PM
When blowing lots of smoke, what color was the smoke ? Blue, black or white ?
What was the last work done on this vehicle?
Old Jun 10, 2024 | 08:46 PM
I would say blueish white. Replaced chains guides adjusters 10k ago along with plugs and coils
Old Jun 11, 2024 | 07:06 AM
Did you use any RTV that might be able to get into the intake system?
Old Jun 11, 2024 | 07:21 AM
I did not
Old Jun 11, 2024 | 07:35 AM
Originally Posted by Kinda93cobra
I did not
I also did a smoke test to check vacuum leaks-none
Checked egr valve on back of intake for soot build up- none
Replaced two upstream and one down stream O2 sensors
Runs fine but it seems the problems starts after idle time.
Does not use coolant but does use some oil.
200k miles it owes me nothing but I like the van but I'm at my wits end
Old Jun 11, 2024 | 09:21 AM
The next thing I would suggest is a compression test.
If you don't have a compression tester, you most likely can rent one.
Ignition disabled, and fuel pump fuse removed, throttle held wide open , run the test and note the max pressure on the gauge for each cyl after 2-3 cycles, record the readings and lets see just what we have, can you do this ?
Old Jun 11, 2024 | 10:09 AM
Ya I can Ive been avoiding it. I'll try to do it this afternoon thank you for your help
Old Jun 11, 2024 | 08:02 PM
When you decide to perform the test,.2024-2025 can you let us know how you make out, thanks.?
jzedder
Jul 11, 2022 06:36 PM
NickLo
Mar 13, 2022 05:50 AM
Philip Heath
Feb 12, 2019 12:08 PM
faadave
Sep 21, 2016 02:17 PM
Big Lew
Nov 14, 2014 12:33 PM
