2004 e250 clunking when downshifting
Old Nov 23, 2023 | 04:25 PM
corolla290's Avatar
Default 2004 e250 clunking when downshifting
Hello everyone happy thanksgiving. My name is Vinny and I’m a new member so I apologize if this is a commonly asked question.
I drive a 2004 ford econoline with a 4.6 liter v8. I’ve replaced the exhaust manifold and gaskets either side, cut out all cats and welded in straight pipe with 02’ sensor spacers to avoid a check engine light. I’ve changed the rear differential fluid and do oil changes. I keep up on the van and it treats me great.
today while driving, when accelerating and going down in gear in the highway, I’m hearing and feeling a slight clunk of sort when hitting the gas and causing the transmission to down shift. I was looking for some pointers here in where to look and how to diagnose this new issue. Thanks. My father said maybe it’s a solenoid on the transmission. My first thought was a possible u joint issue in the driveline. I’m all ears. Thanks I’m advance. I believe it’s making the noise when going from overdrive to 4th gear?
Old Nov 24, 2023 | 08:29 AM
Before assuming anything, it would be a good move to check the U-Joints in the drive line.
If original ,they have no provision for lubrication and do wear out . When they do , they can provide squeaking, vibration, and clunks when placed into gear or whenever the load on the driveshaft is is momentarily reduced or applied.
Looking at them does nothing , they need to be checked when load is applied or they show signs of rust.
If all that is good then a check by a good trans shop might be required.
TheKidWithQuestions
Jun 28, 2023 04:36 PM
fcerv80
Feb 9, 2021 04:40 PM
hhhhhwang
Jul 16, 2013 01:40 AM
doc1550
Dec 11, 2010 10:55 AM
fx4tough
Sep 18, 2007 10:25 PM
