2006 E350 ABS module removal
Old Apr 2, 2023 | 08:29 PM
gotin's Avatar
Default 2006 E350 ABS module removal
the ABS light on my 2006 E350 Extended van comes on and off, I pulled a C1185 code "ABS Power relay output circuit failure". The fuses are fine, and it seems like the relay is in the ABS module so theres not much else to check.
How do you remove the electric harness from the module? And can you just replace the module with a used one, or it needs to be programmed to the car by a dealer?
Old Apr 4, 2023 | 07:03 PM
aquanaut20's Avatar
The replacement unit has to be coded to the vehicle, diagnose the issue before throwing parts at it..
Have you put a scope on it and recorded the wave forms (comms)
Old Jul 29, 2023 | 12:15 PM
dpboone's Avatar
Default ABS module removal and repair.
I had to remove mine, send it for repair, and reinstall last summer. I used this company; https://modulemaster.com/products/ke...rd-abs-rebuild
Roger243
Mar 25, 2023 05:18 PM
Monty51
Sep 14, 2015 06:08 PM
mrcarter9760
Aug 9, 2011 10:40 PM
petec
Oct 20, 2010 10:16 AM
jrouse
Dec 14, 2006 12:55 PM
