2011 radio dead
Old Jan 23, 2020 | 06:19 PM
wa9zug's Avatar
Default 2011 radio dead
I just bought a 2011 e-250 to use as a work van. It was formally a gas company vehicle in Illinois. It is CNG and has 17K miles! The radio does not power on. The fuse under the dash (IIRC 20A) looks OK. I wonder if anyone knows if the gas company disconnected the radios? Any schematics around? It looks like an OEM service manual set is around $120 on dabay.
Old Jan 23, 2020 | 06:50 PM
Should be 3 fuses in the SJB for control of the ACM.
What level of audio does the van have?
Old Jan 24, 2020 | 11:36 PM
wa9zug's Avatar
I am not sure of the level. It is a stripped down van. Manual windows, etc. 3 fuses in the SJB for control of the ACM? Huh? Please explain the terms mi amigo.
Old Jan 25, 2020 | 02:57 PM
The SJB is the smart junction box.
Check fuses F28 5 amp, F39 20 amp, and F41 15amp.
The ACM is audio control module. The ‘level’ would be like base options within the unit like AM only AM/FM, NAV/amp, SYNC and so on.
Depending on options, has a slight difference in the fuses and circuits protected..
Check for power distribution on the input fuses with either a continuity light or meter, not just visual checks..
F28 Hot in Start..
F39 Hot at all times..
F41 would be hot with the delay relay engaged,, meaning key ON/ACC or key off but timed depending on time passed or if the door is open it cancels
Old Jan 26, 2020 | 12:14 PM
Rusty Baker's Avatar
Check the ground first. Then use a meter or test light to see if power is coming into the radio hot wire.
Old Jan 26, 2020 | 04:50 PM
Unless the harness connector has been whacked or altered,, power distribution should be there ‘if’ the fuses are all good. If you need a connector view to check power distribution at the head unit like Rusty mentioned, let me know and I’ll post it...
Old Jan 26, 2020 | 06:02 PM
wa9zug's Avatar
I'll be on this asap. The radio is an AM/FM radio with door speakers. This is a stripped down work van.
Old Jan 29, 2020 | 04:21 PM
wa9zug's Avatar
Default Fixed
Yep, it was a blown 20 amp fuse#39. Thanks Hayapower. The fuse didn't look too bad but I checked it with a meter and it was open.
Old Jan 30, 2020 | 12:01 PM
Thanks for the update
Sean Michael Jones
Apr 13, 2017 10:34 AM
oldad
Mar 12, 2017 07:05 PM
OldAndInThe Way
Jul 30, 2016 02:42 PM
Sgtguerra
Sep 12, 2013 11:45 AM
mesostafa
Jul 20, 2009 04:49 AM
