2013 E-350 parasitic battery drain
Old Jun 27, 2023 | 11:33 AM
Quatro's Avatar
Default 2013 E-350 parasitic battery drain
Hello, first of all, thank you for reading this. I’ve been at this for several days and can’t figure it out. I’ve got fuse F 26 in the smart junction box currently using 3.1 mV. This is the power wire that goes to the IPC. And I can’t figure out what is keeping the IPC awake or what is causing my 0.4 amp battery draw. I have disconnected the multiple modules and other switches underneath the dash and nothing seems to stop this battery draw. Alternator has been replaced due to bad diodes, it helped. Last i called the ipc, oops no fixed. Battery is good. Ford van is isolated from bus. Any suggestions?
Old Jun 27, 2023 | 04:32 PM
You very likely will need a capable scan tool to verify module health and function.
Old Jul 2, 2023 | 09:49 AM
Quatro's Avatar
Thank you I figured it out shortly after posting. It was the park detect switch that broke causing an open circuit.
Merrick
Mar 29, 2023 07:03 PM
Nolan421
Sep 9, 2019 04:28 PM
beckiet
Aug 31, 2017 11:01 PM
manta
Jun 10, 2014 08:35 AM
Wheels45
Mar 29, 2012 01:09 AM
