2014 e150 4.6
Old Sep 8, 2022 | 12:01 PM
Sparky37643's Avatar
Default 2014 e150 4.6
I have a question, had the plugs , oil , and serpentine belt replaced . Now the van stalls out and dies when you brake . It is also giving bank 1 and 2 ox sensor codes . As far as I know the idle re learn was redone . Any suggestions would be appreciated.
Old Sep 9, 2022 | 06:15 AM
What are the codes you are receiving ?
Old Sep 9, 2022 | 06:21 AM
It was coding lean bank 1 and 2 . Both front o2 sensors were replaced . It doesn't die now but the rpms are still a little wonky when braking . It drops to about 4 then spikes up to 600 to 700 rpms . But while it's idling or in motion it's totally fine . It only has issues when braking . They disconnected the battery not sure if the re learn process was done correctly.
Old Sep 9, 2022 | 11:35 AM
raski's Avatar
Lean codes can be set by many things. Some include low fuel pressure, vacuum leaks and even exhaust leaks up stream from the O2 sensors. I would bet the O2 sensors are doing their job.
Old Sep 10, 2022 | 07:28 AM
The problem kinda cleared up yesterday . But this morning it's all back again . Now the codes say the banks are rich . It dies everytime you stop . I'm thinking it's a PCM issue but I am no mechanic.
Old Sep 10, 2022 | 08:05 AM
Hi Sparky,
Lets look at just what happens when you apply the brakes.
The vacuum assisted brakes utilize vacuum to assist with stopping power.
So there is a pretty big demand for vacuum and normally the engine can handle that.
If there is an abnormal amount required it can create a pretty big vacuum demand.
There is a good chance the intake system has a vacuum leak and when you apply the brakes it is more than the engine can normally handle. There is a good chance a vacuum hose was disturbed and is leaking and when you step on the brake the mixture is too lean and the engine stalls..You might look for a cracked , loose or broken vacuum hose connection.
Old Sep 16, 2022 | 02:45 PM
awack's Avatar
See pots below.. This sounds like a Vacuum leak as others have stated.
Old Sep 16, 2022 | 03:00 PM
I'm not sure what different parts your talking about . I just had the plugs changed and now it dies when I stop or brake . Also the rpm gauge was reading 0 and I was driving . Then it just starts working again .
Old Sep 16, 2022 | 03:03 PM
awack's Avatar
sorry my post above was for a different thread.. not sure how that happened.. It sounds like you have a Vacuum leak.
You have lots of Vacuum lines all over it and anyone of them leaking will cause symptoms like yours. Look up how to do a Vacuum Test. Go get yourself a Vacuum gauge and have at it. It only takes one cracked rubber hose.. It is Very possible when the Plugs were changed someone pulled on a hose a bit to hard and cracked one.. They get dry and stiff with age. Like us
maagk
Feb 26, 2018 10:35 PM
texasmark
Dec 15, 2015 06:09 PM
NikjMiles
Jul 20, 2014 11:10 PM
shomurph
May 29, 2014 06:21 PM
Bhip56
Apr 30, 2014 02:25 PM
