4x4 van conversion
Old Jan 27, 2020 | 08:22 AM
jeffreysloan1's Avatar
Default 4x4 van conversion
Currently trying to start a 1999 E350 2wd to 4wd conversion, already have axles, drive shafts, transfer case and front 6 inch leaf springs, has anyone done this before? Looking for some part numbers and such of things I might need or want. Any help would be much appreciated thank you!
Old Apr 26, 2021 | 08:33 PM
TallTex's Avatar
Default No reply after a year?
hmmm, I just joined, after more than one year, it appears like you found no interest and no response to your questions. Maybe we are not in the correct forum? What research did you do when sourcing the parts? What makes best donor parts vehicle? If you know. I have a 99 E250 extended, high-top that I converted into a motovan. Now thinking about the 4WD conversion also.
Old Apr 26, 2021 | 10:35 PM
Nearly anything can be converted with enough time, cash, and determination.
Back in the late 70’s we used to converter gas F250’s to Perkins, Detroit Diesels. Most of which involved much fab. If converting from 2x4 to 4x4 if you have a donor truck would help eliminate many hurdles. Better if it’s was manual 4x convert and not ESO4 etc..
Alaska57
Feb 13, 2014 08:22 PM
Hongster
Jan 5, 2012 09:50 PM
thechadjd
Nov 11, 2011 08:25 AM
CRBay
Jan 22, 2009 12:27 PM
bikesandcars
May 1, 2007 01:47 AM
