93 e150 clockspring
Old May 21, 2021 | 07:45 PM
Michael Duquette's Avatar
Default 93 e150 clockspring
Heyas) I just bought a 1993 e 150 conversion van awesome shape low miles etc however.....Airbag code 12 no horn and no cruise. Eveything I have been able to find indicates bad clockspring and I cannot find one. Every search part comes up discontinued. It's a ford part number f3uz 14a664-b. Thought i'd post here and cross my fingers that someone has one or a source to buy one. Thanks!
Mike
Old May 21, 2021 | 08:13 PM
You might try, Vintage Parts Inc
Located in, Beaver Dam, Wisc.
Old May 21, 2021 | 08:31 PM
Thanks for the help. Unfortunately they don't have one ;(
Old May 22, 2021 | 03:55 PM
Have you considered a salvage yard ?
Sometimes they may require you purchase the entire steering column, it would still be worth it , provided the clockspring in that unit is not broken.
Old May 22, 2021 | 07:56 PM
I have, and I am still looking. I have a few feelers out. Thanks!
Old Nov 27, 2021 | 01:10 AM
Slow ride's Avatar
Any lucky with this? I also have a 93 and in need of one.
thanks
Old Nov 27, 2021 | 06:15 AM
Sometimes a part is used in several models/years.
Ford dealership parts dept should be able to tell you if part # is used in more than one year/model. Worth a try.
Old Nov 27, 2021 | 08:40 AM
thanks
I used one from a 94. I had to move a couple wires around on the moulded plugs to match the locations on my old one but it worked just fine. There is a red plastic keeper inside the plug if you pull it out it will release the hold on the wires then they can be repositioned into the correct spots. Good luck!!
grandmarq
Jun 8, 2013 08:16 PM
DonsFords
Nov 20, 2011 05:03 PM
cboy369
Feb 11, 2011 03:25 PM
llacrosse
Dec 22, 2009 02:00 PM
sjbboy38
Jan 9, 2007 03:24 PM
