Brake rotors for '94 E-150 van conversion by Sherrod
Old Oct 20, 2025 | 04:12 PM
Geneeus's Avatar
Default Brake rotors for '94 E-150 van conversion by Sherrod
Hi,
I have a 1994 e-150 van conversion by Sherrod. I need to replace my rotors and pads, but I don't know if this is a standard van or a "Club Wagon." The vin indicates it was delivered as an "incomplete" vehicle.
Any suggestions would be very much appreciated.
Model - 150
Model Year - 1994
Plant City - LORAIN
Series - Econoline
Trim - Regular Van
Vehicle Type - INCOMPLETE VEHICLE
Body Image Id - 95
Body Class - Cargo Van
Gross Vehicle Weight Rating From - Class 2E: 6,001 - 7,000 lb (2,722 - 3,175 kg)
Trailer Type Connection -
Drive Type 4x2
Brake System Type Hydraulic
Number of Cylinders 8
Displacement (CI) 351
Displacement (L) 5.8
Engine Power (k W) 152.8685
Fuel Type- Primary Gasoline
Engine Brake(hp) From 205
Engine Brake(hp) To 210
Other Engine Info Fuel Injection Type: Electronic Fuel Injection
VIN
1FD E E14 H 1 R H AXXXX
Position 1 Country of origin (USA)
Position Manufacturer (Ford)
Position 3 Type of vehicle (Incomplete Vehicle)
Position 4 Gross Vehicle Weight Rating (5001-6000 lbs.)
Position 5-7 Line, Series, Body Type (Econoline E-150 Cargo Van)
Position 8 Engine Type (5.8L V8 OHV)
Position 9 Check Digit (Ignore)
Position 10 Model Year (1994)
Position 11 Assembly Plant (Lorain, Ohio)
Position 12-17 Production Sequence Number
5th, 6th, 7th Position (Line, Series, Body Type)
Geneeus
Old Oct 21, 2025 | 03:32 PM
If you go to a dealership parts dept or a REAL auto supply store like NAPA just give them the info and they will according to the info you provide (from the sticker on the door)
and you will obtain the right parts.
SPONTINI
Mar 13, 2024 06:25 AM
alex w
Jul 22, 2022 12:24 PM
JWLKR
Oct 14, 2018 07:42 PM
madmax23
Jul 5, 2012 09:20 PM
thelree
May 9, 2006 12:13 AM
