Brakes
Hello I'm learning as I go here. I'm having trouble with my transmission shifting in and out of gear. I replaced the instrument cluster guage, the vss , and various other parts. The van has 250k. I think i have narrowed it down (lol) to the front abs sensors, or a bad wire. I noticed the front bushings are shot and the passenger side wheel bearing needs to be replaced. My question is can I unplug the front abs sensors and drive it to see if it makes a difference, or is that even possible ? It's a 96 E 350 15 passenger with a 7.5L 460 . Any help is appreciated, thanks in advance.
You can unplug the sensor/s and drive it but it will set codes.
But,, the items you’ve replaced doesn’t follow an issue with the van coming in/out of gear..Unless unrelated..
Is it more that the van has trouble being pulled out of Park? Generally you don’t see issues going back into Park unless there’s a shifter/tube/lower column arm problem..
