Cilinder misfire E250 2002
Old Nov 18, 2024 | 07:45 AM
Frank507's Avatar
Default Cilinder misfire E250 2002
Hi, my E250 2002 is having a couple of misfires. Complety lack of power, i just replaced all the spark plugs, the wires and i instaled a new ignition coil pack too. Its like 2 or 3 cilinders are mising out. The engine was rectified recently . Im not sure what's going on and what its the next step. The old spark plug turned black in the top. I have a video that show the misfire better, but i can't share it because the format. Thanks for your suport and feedback about model E
Old Nov 18, 2024 | 11:46 AM
It would help if we knew the engine size.
Could you bring us up to speed on what rectified means in this case ?
Could you tell us how long after the engine work was done the problem showed up or was it there before.
Old Nov 18, 2024 | 01:08 PM
Frank507's Avatar
sure , its a 4.2L, V6
Old Nov 18, 2024 | 01:33 PM
Frank507's Avatar
the problem started in october , i got the truck since december 2023
Old Nov 18, 2024 | 01:45 PM
Did the misfire problem show up after replacing plugs and wires?
Old Nov 18, 2024 | 01:57 PM
Frank507's Avatar
Yes , i have the problem before , thats the reason why i had change the spark plugs, and the ignition coil, when i went to my hometown in the road i faced this situation, soon i get home, first, my mechanic told me that the ignition coil pack is failing, so i replaced, later i replace the six spark plugs, with new wires. But the trouble persist...
Old Nov 18, 2024 | 02:11 PM
When replacing the spark plug wires, did you pull them all off and replace them or did you do the wires one at a time?
There is a particular order that the spark plug wires go onto the coil.. Can you tell me how you installed those wires on to the coil ?
Old Nov 18, 2024 | 02:28 PM
Frank507's Avatar
i replaced all, and also i did it 2 times, because my father sugest that i needed to change the pack i bought because he thinks all was damaged, i know the ignition order , because i got a picture with the image of the cilinders and the start order. The truck start but in a weak way.
Old Nov 18, 2024 | 04:36 PM
The spark plug wires do a crazy thing when getting installed in the coil towers..
The wires go,,,,,,,,1-2-3-4-6-5 make sure the wires for each cyl follow that order on the coil.
If not can produce power problem and misfires.
Old Nov 18, 2024 | 05:06 PM
Frank507's Avatar
sure , i did it in this way
