Do an E350 cargo van have bolt holes for rear seats?
Old Mar 8, 2020 | 03:04 PM
Fnlboy's Avatar
Default Do an E350 cargo van have bolt holes for rear seats?
I just got a 2011 E350 to pull my camper trailer. It has no rear seats but does have a vinyl floor in the back so I can't see if there are threaded bolt holes for seat mounts without pulling all the trim. I found a 2nd row seat with mounts, but don't know if I can install them.
Old Mar 9, 2020 | 03:47 PM
Rusty Baker's Avatar
I don't know. I can tell you that my 94 E 150 does not have bolt holes for seats. The 85 I owned had bolt holes but not threaded ones.
Old Mar 14, 2020 | 09:57 AM
If you are contemplating installing rear seats, keep in mind the bolts through the floor need to have plating underneath to dissipate the force and the same requirement goes for seat belts.
Old Mar 26, 2020 | 02:22 PM
Fnlboy's Avatar
Looks like the original seat mounts through the floor support beams to dissipate the force. I haven't figured out the seat belts yet. I assume they too pass through the support rails.
Old Mar 28, 2020 | 10:26 AM
On some years, the seat belts fasten to the seats, not the floor.
Old May 7, 2020 | 04:06 PM
Classic HD Cycles's Avatar
Default Can you explain?
hi, I’m getting ready to install a four seater, can you share where you bolted, I saw so much under the van I was like, whoa😱
Your help would be greatly appreciated.
Old Feb 14, 2024 | 03:36 PM
Van_life's Avatar
Default Safe and Secure Seats
Check out cvcandmore.com, they have safe and secure seats that are DOT and FMVSS compliant, all their seating systems are Pull-tested too. They have seats for all Full Size Cargo Vans, Passenger Vans like Ford Transit and MB Sprinter that click into the Orgianl Factory Floor Seat Tracks. They have modular removable seats and Swivel seats too which are also removable.
dos gatos locos
Jun 28, 2021 06:00 PM
thewheelman56
May 7, 2020 04:15 PM
McStein
Sep 22, 2018 01:26 PM
vaughandw
Apr 16, 2012 06:36 PM
rgaller
Sep 16, 2010 11:18 AM
