E-250 keep throwing p0174 codes
Old Jun 19, 2023 | 03:04 PM
Fremont Troll's Avatar
Default E-250 keep throwing p0174 codes
My 2004 e250 is on its second remanufactured engine and throws an p0174 code with regularity, like three times in one day, recently. I realize that this is a "System Too Lean, Bank No. 2".
I am curious why this code was displayed on the van's original engine (98,000 miles) and on the replacement remanufactured engine and now on the second remanufactured engine?
Should I devote time and attention to finding the fault causing the "Check Engine Light" or maybe see if there is an issue with the ECU, which has not been replaced since the original engine.
Any advice will be greatly appreciated.
Old Jun 20, 2023 | 09:32 AM
Certain conditions must be met before the PCM will submit a code.
It would be a good move to examine those conditions and verify either they are or are not present.
A capable scan tool with Freeze Frame capability will show the conditions at the time the code was set. And,, we go from there.
Old Jun 20, 2023 | 11:53 AM
Thank you Hanky,
I will dig further into the instructions of my Scanguage II and see if I can retrieve the PIDs
ugh3012
Nov 4, 2012 03:40 PM
ford777
Feb 26, 2012 08:33 PM
Robert Wiercinski
Jun 30, 2011 08:07 PM
gtidanj
Jan 23, 2010 03:57 PM
rmd8123
Jan 8, 2009 03:18 AM
