e250 body mounts
Old Jun 4, 2018 | 09:37 PM
login8188's Avatar
Default e250 body mounts
So I recently bought a 2001 e250 van, and am fixing it up a bit- suspension currently.
Anyways, I noticed a couple of the body mounts need replacing and need to know a few things: 1. how many body mounts are there? 2. is there somewhere online that points out where these mounts are? 3. Any tips you'd like to impart?
thanks!
Old Sep 24, 2023 | 08:15 AM
becksterorange's Avatar
I know that this is an insanely old post, but after my 3-day nightmare of changing all the body mounts on my E 350, and not finding much information or tips at all, I felt compelled to reply. There are 12 mounts total. Six on each side. I could not find anything online that pointed to where they are. However, they are easy to locate if you look on top of the frame. As for removing them, buy several new 6 inch and 9 inch sawzall blades for metal. Do one side at a time. Try to take out ALL the body mount bolts on the side you are working on. If they break don't worry. Next, safely, jack the frame up just enough to get the sawzall blade under the bushing on top of the frame. If you leave weight on then the blade will bind. Proceed to cut each of the top bushings off. Finally, replace with the new mounts.
You have to remove the front bumper to access the position 1 mounts. But, the technique is the same.
I spent 3 days figuring out how to best do this. Once I figured it out, it only took me about 2 hours a side.
Good Luck
Old Feb 1, 2024 | 12:42 PM
babyjavier1's Avatar
Default Where did you find mounts? Do you have to remove anything else besides bumper?
Good Luck
Where did you buy the mounts and besides the bumper is there anything else that needs to come off?
Old Feb 2, 2024 | 05:04 PM
I bought them from RockAuto. I also had to remove one of the rear seat mounts.
Old Feb 2, 2024 | 10:05 PM
Default Thank you
Sir thank you again. I have an E 150 and I did see under the van 12 mounts. I saw that some on the left side middle by the fuel thank seems a little hard to get to the mounts. I will study it like you did and see if I can do it. Will post when I get to do it when the weather gets better.
Old Nov 20, 2024 | 06:27 PM
Craig_lawrence's Avatar
Good Luck
did you use the Dooorman parts? I’m trying to replace my bushings on a 1997 e150 and am concerned the parts won’t fit. Position 5 looks too tall. Can you confirm the parts worked?
Old Nov 21, 2024 | 06:27 AM
Yes I used Dorman. I bought them from rockauto.
Old Nov 21, 2024 | 08:00 AM
Thanks for the quick response! What year and model is your van? Did you have any issues with position #5 being taller? My mechanic is reluctant to get started because he’s worried the parts won’t fit. I’m trying to get him some reassurance.
Old Nov 21, 2024 | 09:00 AM
Mine was a 2012 E350.
I had no problems with parts fitting.
Old Nov 21, 2024 | 09:03 AM
They were different sizes but once I got started it was obvious which ones went where.
85 econoline "Chester"
Dec 16, 2018 08:43 PM
mrgmman
May 22, 2011 04:00 PM
johnissamoan
Mar 2, 2011 10:26 PM
money520
Jul 18, 2010 09:11 PM
bikesandcars
Apr 26, 2007 12:22 AM
