e250 trans
Old Nov 21, 2020 | 06:54 AM
raykotlarz's Avatar
Default e250 trans
i have a 2009 e 250 with 55thousand miles and the trans is slipping my last 3 ford vans had high millage and never had a problem
Old Nov 21, 2020 | 07:05 AM
Is it slipping in certain gears or at all times?
Has trans ever been serviced?
Old Nov 21, 2020 | 07:55 AM
raykotlarz's Avatar
Default trans
it only slips rarely when at a stop i alwaycheck fluid levels thanks
Old Nov 21, 2020 | 02:24 PM
You are waltzing around on me . Just kidding, There is a difference between checking the fluid level and having the trans serviced. What does your owner's manual recommend?
Old Nov 22, 2020 | 01:16 AM
raski's Avatar
If your fluid level is where it needs to be, I would suggest to seek a good transmission shop. At 55k miles, that tranny is slipping because of a mechanical failure not because the fluid and filter have never been changed. The more you drive it that way, the more damage to clutches will occur.
Old Nov 22, 2020 | 06:07 AM
There is a reason why we change the fluid and filter.
If the filter becomes restricted the pump can't get sufficient fluid to pressurize the system and one of the results is clutches not fully applied and slippage which results in excessive clutch disc wear and eventual destruction.
Old Nov 22, 2020 | 07:55 AM
raski's Avatar
Yes, I agree with fluid and filter changes. However, if the filter becomes so loaded that it is restricting fluid flow enough to cause his issues in 55k miles, he's got bigger issues than just the filter. That debris came from somewhere, probably clutch material.The best advice is to seek out a good transmission shop for a consultation.
sandman2230
Dec 16, 2009 09:05 PM
hunter
Jul 9, 2009 11:32 AM
STEVE1103
Jun 6, 2005 06:16 PM
STEVE1103
Mar 3, 2005 04:32 PM
STEVE1103
Mar 3, 2005 11:19 AM
