Fed Surveillance Van w/alt problem
Old Sep 22, 2012 | 04:15 PM
OldBob's Avatar
Default Fed Surveillance Van w/alt problem
Why would my old alternator and my new one both be putting out only 11 volts?
I put in a new voltage regulator with the change.
This van is a wiring nightmare. The Feds had a bunch of electronics in it that they ripped out. Could this be a place to start my search?
Should mention that this thing has the duel battery option so the battery side connector goes there first. When I metered it I went straight from the alternators bat. post though.
Old Sep 22, 2012 | 04:33 PM
Don't know how much help we can provide if any, but would be helpful to know what year , what engine and any other info you can provide.
Old Sep 22, 2012 | 04:43 PM
OldBob's Avatar
Thanks, I spaced out.
1991 E-250 3.8l (351ci).
Old Sep 22, 2012 | 05:42 PM
thexlo8ers's Avatar
On the voltage regulator make sure the "Field" wire (marked "F") is good from there to the alternator connection also marked "Field". This is the wire that "tells" the Alt. increase output to supply charging voltage.
Old Sep 22, 2012 | 09:34 PM
OldBob's Avatar
Great! I was just talking about this at dinner with friends. I was saying that something has to "talk" to the alt from the VR.
I'll check that in the morning (this being Saturday night).
Old Sep 24, 2012 | 01:12 PM
OldBob's Avatar
theXlo8tors,
You were right. It took a little doing but I found a break in the field wire to the VR.
Thanks for your help.
OldBob
Old Sep 24, 2012 | 07:15 PM
thexlo8ers's Avatar
Glad you found the problem.
Thanks for posting an update, and you're welcome. Glad I was of some help.
Sad Ford Fan
May 8, 2012 04:27 PM
darrell69
Aug 3, 2009 09:12 AM
Lil Blue
Oct 5, 2008 06:20 PM
mcleaves
Aug 19, 2008 12:44 PM
jmontross
Dec 6, 2007 10:00 PM
