which fuse is for the fuel pumps for a '89 E150 302
Old Aug 8, 2021 | 10:31 AM
Welderguy's Avatar
Default which fuse is for the fuel pumps for a '89 E150 302
I am trying to find which fuse powers the high pressure fuel pump on my '89 302 E-150. I have pulled 3 and they were not the one I need, the fuel is still pumped out! I looked on google for the answer, I continually found it suggested to be fuse #18, which is a blue 15 amp. but for my van, I discovered that is not the fuse for the fuel pumps. Does any one know for sure which fuse it actually is, and where on the fuse panel it is located?
Old Aug 8, 2021 | 12:33 PM
If you are looking at the fuse panel, there are 2 fuses right on top with the flasher to the right side. , it should be the one on the left (driver) side.
Keep in mind there is an inertia switch located on the passenger side top of kick panel. You may not see it , but if you feel up there you can feel the button that should be in the down position. If you give that area a good rap you will hear the switch trip and the ball roll. That will interrupt power to the fuel pump assy
All you do to reset it is, push the button back down.
Old Aug 8, 2021 | 07:07 PM
Rusty Baker's Avatar
Hanky, what year did they add the "inertia" switch?
Old Aug 9, 2021 | 07:17 AM
I believe just about all fuel injected vehicles have a type of inertia switch to prevent fuel spill in event of a collision.
Not sure of exact year.
super6
Aug 10, 2019 12:55 PM
gthomson
Sep 9, 2010 10:54 AM
allblue
Mar 25, 2010 02:36 PM
dkjones3
Apr 13, 2009 04:33 PM
89 5.0
Feb 2, 2008 02:14 PM
