I need to swap engines in my vans
Old Mar 28, 2007 | 03:16 AM
shuravloff's Avatar
Default I need to swap engines in my vans
I have a 1979 chateau club wagon with a V6 and I want to swap the V6 with a 302 out of an 85 half ton regular size van. The 85 has a carb so no efi stuff on it. Is this going to be an easy swap or impossible? Any suggestions on the roadblocks I'll run into?
Old Mar 28, 2007 | 03:55 PM
goinstrong's Avatar
Default RE: I need to swap engines in my vans
May need special oil pan and pickup tube if crossmember is in the way. You'll have to change transmissions also in all likelyhood which also means change driveshafts (likely different length engine/trans. assemblies even if only an inch). Might need a new length or the other shifter arm for other trans. '85 might have a throttle body injection (injectors in a carb body). An actual carb. might not fit this intake in this casethe intake willneed changed. You'll need a new wiring harness or maybe just the ignition computer. V6 and V8 don't match right (although some 4 cylinder and V8 do). Might want to look to custom fit a V-8 radiator in before you begin (remove when putting in the motor etc. - of course) and your fuel pump will need to be changed to an inline electric one (goes right in the fuel line - usually closer to the tank - don't forget a pre-pump fuel filter).
Old Mar 28, 2007 | 03:56 PM
goinstrong's Avatar
Basically if you want it you may as well transplant the whole deal - but undoubtedly you'll be happy in the end.
eric souther
May 30, 2025 09:51 PM
JeaniSue
Dec 30, 2007 02:14 PM
bikesandcars
Apr 16, 2007 12:37 PM
shuravloff
Mar 28, 2007 03:16 AM
1950charlie
Oct 9, 2005 02:44 PM
