Info on Rear Fuel Tank
Old Jun 4, 2021 | 05:21 AM
  #11
fraz627's Avatar
I just bought it, and today I went to put fuel in, the front (normal) fuel neck is factory blocked off. Next week I'm going to get it on a lift and reall be able to check it out.
Old Jun 4, 2021 | 11:25 AM
  #12
If the front tank is blocked from being filled at the pump, there probably is a "crossover" line that allows fuel from the rear tank to also go to the front tank and maybe only one in tank fuel pump..
Old Jun 5, 2021 | 03:57 PM
  #13
Rusty Baker's Avatar
Hanky, do you mean it could be gravity flow instead of a pump? If so, wouldn't one tank need to be installed higher than the other one? That should be an easy way to tell.
Old Jun 5, 2021 | 04:12 PM
  #14
Without actually looking at the set up , can only conclude they are probably close to the same level. Depending on which tank has the fuel gauge , the fuel will always be at the same level in both tanks as long as they are at a similar height... We are not able to know all the info with the vehicle being there and we here.
Just about all diesel trucks with 2 tanks pull from one tank , have one gauge, , but the do have a crossover line that allows fuel to flow from one tank to the other. If each tank has a capacity of 100 gals. and the gauge reads one-half. the total capacity is still 100 gals.. Because it takes a long time for the fuel to flow from one tank to the other. that is why you see drivers fuel both tanks , it is just quicker.
The crossover line is usually only 3/8 in ID. The level does equalize, just slowly.
70ford
Mar 5, 2022 04:40 PM
94f150
Oct 17, 2020 07:06 AM
Steve94951
Apr 12, 2013 03:41 AM
two bit okie
Apr 27, 2012 12:15 PM
mxtreme311
Dec 20, 2010 04:38 PM
