Location of temp sending unit and the ECT 96 e150 5.8
Old Dec 16, 2023 | 07:01 PM
Teressa's Avatar
Default Location of temp sending unit and the ECT 96 e150 5.8
I have a 1996 e150 econoline van, 5.8 liter, auto trans. I am not mechanic, just a 63yr old female whose owned this van 26yrs and do a lot of the maintenance. Brakes, heater core, joints no problem, but I'm simply stuck on locating either of the two temp sensors. I didn't realize there was two of them B4 I started researching. I'm first wanting to change our the sending unit as never been done at 240,000 miles, and while van runs great but for very high idle, my interior temp gauge suddenly started showing 20,-25% increase. No fluid loss. Was driving hwy speed on cool night, and while it seems to remain halfway between normal and hot, it's totally out of character, which concerns me. Fixing to drive back to tx from NW Washington and want to know why all of sudden is running hotter. New radiator, cap, hoses. Water pump ok, no head issue. Thermostat seems to be ok, and doubt it's a fan sensor cuz of how it presented. Since cheap fix to replace sending unit, wanted to start there. Took the air filter n housing off. Still can't tell where it is. Do I have to remove a hose to access sending unit? What about this secondary ECT sensor supposedly located in standpipe? Read it can affect idle speed n gas mileage plus temperature. Should I replace it also, or clean/check the MAF sensor and IAC sensor fir Options
gotahammer
Jan 29, 2020 12:47 PM
dplantz
Jan 2, 2016 12:36 PM
caisert
Apr 17, 2013 08:25 AM
barnall
Aug 30, 2010 11:04 AM
johnduckred
Jul 29, 2007 04:11 PM
