must pump brakes pedal 3 times to stop
Old Sep 6, 2006 | 03:54 AM
oscar7777's Avatar
Default must pump brakes pedal 3 times to stop
I have to pump my brakes twice, then the pedal is off the floor and hard...and the brakes are great. But he pedal should not need to be pumped.
I have beld the brakes hydraulic system. So there should not be any air in the lines. But what is the solution? I want to press the pedal once and have the brakes function properly.
Old Sep 6, 2006 | 09:06 AM
94 4x4 ranger's Avatar
Default RE: must pump brakes pedal 3 times to stop
You may have a leak in the system. Does it loose fluid?
Old Sep 6, 2006 | 08:27 PM
goon's Avatar
if no leaks adjust your back brakes. Get the back wheels off the ground and you want a little drag on the rear brakes
Old Sep 8, 2006 | 12:22 AM
Mulletman's Avatar
Agreed! First check for visible leaks, then check rear brakes for proper adjustment.
Ejackson
Apr 21, 2015 02:25 AM
helpford
Nov 12, 2008 11:35 PM
jhatten
Feb 13, 2008 02:20 PM
Sooner0233
Feb 4, 2008 10:43 PM
drewi
Apr 12, 2006 11:40 AM
