Is my transmission gone
Old Oct 28, 2007 | 06:09 PM
money520's Avatar
Default Is my transmission gone
Here's my deal my 1995 E250 handicap van has 101,000 on it, just started idling real high now it's shifting hard and it has to to be at high rpm's to shift into a higher gear it's like the overdrive is gone do you think a rebuild kit will work or sound like the transmission is gone? It's a 5.8L.
Old Oct 28, 2007 | 11:39 PM
Harrlock's Avatar
Default RE: Is my transmission gone
Check the fluid level and quality.
Old Oct 28, 2007 | 11:44 PM
liljoey007's Avatar
hey money,the trans fluid level will not cause it to have a high idle.it sounds like you have a bad tps sensor.that will cause a high or erratic idle and for the trans to shift poorly.......
Old Nov 1, 2007 | 04:52 PM
money520's Avatar
Had the tps sensor changed that fixed the idel problem but but it's still shifting pretty hard any ideas why?
Scott
Gasman_66
Aug 5, 2009 10:42 PM
BUSTYSIN
Nov 30, 2006 01:57 PM
ifiteluihaf2kilu
Dec 24, 2005 01:46 PM
mmmahlstede
Aug 29, 2005 01:12 AM
