No power. Transmission?
Old Dec 21, 2018 | 11:40 PM
JamesPlzHelp's Avatar
Default No power. Transmission?
I have a Ford econoline e250 2013. I was driving the van today and suddenly my car shook. Then I lost power and if I hit the gas pedal, my rpm gauge revs to the red line even when I let go the gas pedal. As I continue to drive it, the car would shook again and power is restored. Then it would lose power again. It happens over and over. Is there any possible causes?
Old Dec 22, 2018 | 03:09 AM
Any check eng lite?
Sounds like a problem with throttle body, Electronic throttle, drive by wire.
Old Dec 22, 2018 | 03:39 AM
No check engine. I think it might be the transmission torque converter. My van makes a whining noise and revs up to the red bar even when I let go of the gas. However, there is no power. Should I take it in to ford to have them take a look at it? Do you think I’ll be pricey?
Old Dec 22, 2018 | 09:58 AM
Welcome to the site..
For clarity, your saying that when the van won’t move it ‘red lines’ with a throttle application, then, when you remove your foot the throttle remains at red line?
Generally with no movement and a whine may indicate trans front pump cavitation from low fill level, or a pump issue, but shouldn’t have a continuous WOT. as part of the condition. Any indication of a fluid leak?
Old Dec 22, 2018 | 07:00 PM
When I give it gas, it works fine but as the rpm gets higher, the van shakes for a second. It loses power and when I give it gas, it only revs. When I let go of the gas, it continues to rev for a while and drops down back to normal. Then I continued to tap the gas pedal until my van shakes. Then my van would have power.
Grnmstr
Feb 10, 2019 08:17 PM
jeff_focus
Oct 18, 2013 07:07 AM
Mitham
Aug 11, 2007 01:28 PM
lthacker
Mar 5, 2007 10:59 PM
ESCORTSRUS1989
Jul 4, 2005 01:06 PM
