No starting and no electrical power anywhere
Old Apr 5, 2022 | 05:07 PM
  #11
Thank you for sharing that info with us.
Those darn electrons can get pretty fussy and don't always go where we need them to go.
Old Apr 6, 2022 | 08:35 PM
  #12
Greg K's Avatar
I just noticed, both times the original problem went away after he closed the hood. Could be a weak electrical connection and the vibration helped. I'd clean the battery terminals and cable connections first.
There's nothing like a good battery and cables to keep gremlins away.
Old Aug 3, 2022 | 05:47 PM
  #13
MartinTravels's Avatar
RESOLUTION:
It has been several months since I posted this, and I have resolved the problem. I ended up taking the battery out, cleaned the terminals (even though they were already very clean), and reconnected the battery cables. Since doing this I've not had an issue. The original connection seemed mechanically very solid, but my suspicion is that there was a bad connection somewhere on the positive or negative cable. The simple act of disconnecting each cable and then reconnecting them must have fixed the bad connection. Thank you all for your input, advice and help!
Old Aug 3, 2022 | 06:59 PM
  #14
Hi Martin,
You hit the nail on the head removing and cleaning cable ends that looked OK but had oxidation between the battery post and the cable inside hole.
Many folks including some mechanics get fooled looking at a battery cable end that looks fine , but can be NO GOOD and has to be removed and physically cleaned.
Thanks for sharing that info with us.
tstamos95
Oct 26, 2021 09:54 PM
fordy1
Feb 4, 2021 01:50 PM
rod525
Nov 2, 2014 05:32 PM
deadendstreet
Oct 28, 2013 12:38 PM
INDA605
Mar 1, 2012 07:41 PM
