Puzzle
Oh I have plenty to do. I am putting a metal roof on my house and at 67 nothing goes fast.
You gotta be in great shape because I have heard from others that were younger , the memory goes, the energy goes, the eyesight goes, the hearing goes and oh yea that other part is gone also ! And ,,,,,,,,,some of it went fast too !
I don't know if you are using new parts or used parts however I have been having issues with my passenger window motor for over a year now. Granted I was using Pick A Part as my parts supplier but even so the window would work for a month or so and then go dead and work intermittently. If I hit a bump or banged on the door panel it would work sometimes and not others.
As with you the motor worked fine when out of the door and hooked to the battery but would flinch or not work when hooked to the window regulator assembly and other times it would. I finally disassembled the motor and found that the brushed were warn completely down and the armature was black from carbon build up. I went back to the wrecking yard and found a much newer vehicle with matching window motors and bought them. So far I have not had any issues with my windows knock on wood. Hope this can help you out?
