Rear air ducts not working
Old Feb 16, 2016 | 01:47 PM
FordGirl!'s Avatar
Default Rear air ducts not working
Hi all,
I drive a 2005 Econoline van for a non-profit organization. Last week, the rear air ducts quit working. It's not working for A/C, heat or vent. I can feel the refrigeration line that runs along the driver side to the back and it is cold. I can hear the fan at the rear and it works thru all the different speeds.
I'm assuming that there is some kind of door at or near the rear fan that is not working. Can someone confirm this and how to get at it? I've looked at the plastic panels, but I don't want to go *****-nilly trying to pop them off and end up breaking something.
BTW, the front ones at the dash are fine
Thank you in advance for the help!
Old Feb 17, 2016 | 10:17 AM
LakelandFordParts's Avatar
Former Sponsor
The only thing that comes to mind for me is the blend door. I would definitely suggest getting a diagnosis from a mechanic but if it does end up being the blend door then you will need to look into part number XC2Z-19E616-AA (#XC2Z19E616AA: Actuator. Adjust motor. Motor assy.) for your vehicle.
Old Feb 18, 2016 | 07:44 PM
FordGirl!'s Avatar
Thank you! I'm sure that's it. Maybe a vac line, maybe the door itself. Getting those panels off will be the next trick.
Thanks again for your reply
Old Feb 19, 2016 | 08:38 AM
Former Sponsor
Yeah, this job can be a bear. It may be worth signing up for All-Data DIY.
Old Feb 19, 2016 | 12:14 PM
Alanah_Rae's Avatar
You are right lake. Thanks for the info.!!
reynard
Dec 6, 2023 03:25 AM
Duke2011
Dec 6, 2011 10:58 PM
MGood777
Sep 27, 2008 07:57 PM
Mohawklio
Feb 9, 2008 12:49 AM
krittrkeepr
Jan 14, 2006 09:27 PM
