replacing key ignition keeping same key
Old May 12, 2016 | 10:32 PM
  #11
With the key in the ignition,,, if the 'Winged' portion of the ignition in NOT in alignment with the inserted key itself, then the crimp that holds the wing portion tight has come loose. With the key out of the ignition if you can move the wing portion any significant amount, OR, to the point where the key can not now be inserted, the crimp on the lock set has come loose.
The reason they offer a 'key-able' replacement lock set is so you can key it to the originals keys 'profile'. It's common for the ignition lock to come loose. Ive replaced quite a few over the years...
Old May 13, 2016 | 02:02 PM
  #12
Alanah_Rae's Avatar
Great info haya !!
kstbird
Jan 27, 2008 08:15 PM
tsaico
May 8, 2007 07:09 AM
turbo79
Nov 30, 2006 11:18 PM
red
Nov 20, 2006 07:04 PM
lobsteroll3
Aug 5, 2005 02:29 AM
