Transmission Flush Concern
Old Jun 13, 2017 | 09:09 PM
jjb's Avatar
jjb
Default Transmission Flush Concern
I have a 2010 E-150, 4.6L V8 engine. Ford dealer recommends a Transmission flush as part of 60,000 mile service. In the past, I've heard that tranny flushes should not be done. What's the best way to change the ATF? .
Also, small maintenance guide states to change the AT filter when vehicle has a TorqShift transmission. How can I determine if I have a TorqShift transmission?
Old Jun 15, 2017 | 08:01 PM
On your vehicle's door label should be a code letter/number for "TR" , the transmission code in the vehicle. Can you supply that info?
The Torqueshift trans was intended for use with diesel engines, good possibility you have a 6R80 trans,
Old Jun 16, 2017 | 10:02 AM
jjb's Avatar
jjb
Hanky- The only "TR" nomenclature I found on door is "INT TR XW". Just back from Ford dealer. I gave Ford VIN # and they said I did not have a TorqShift trans. As you probably realize, I don't have a diesel engine. I've called 3 Ford dealers near me and they all do the trans flush. Still a little concerned about flushing the trans, but leaning in that direction. Thanks for your response!
Old Jun 16, 2017 | 11:02 AM
Trans 'flush' isn't the standard any longer,, the trans fluid is 'exchanged' now, meaning just that and doesn't raise any concerns.
Old Jun 16, 2017 | 02:55 PM
jjb's Avatar
jjb
Hayapower-Very good point!!!! ! Although Service Advisors referred to it, and explained it as a Trans flush, dealer cost service sheets refers to it as a "Fluid Exchange". It appeared to me that the Service Advisors I spoke with were not up to date. Feeling more confident now. Appreciate your input!!
FYI-15 years ago I had a trans flush done on an older, but perfectly fine Chrysler trans which did not go well. Trans started declining a few weeks later. Hence my initial concern.
Eligee1
Jan 19, 2012 11:09 PM
CRiSS
Nov 5, 2011 05:37 PM
jduke
Oct 4, 2007 12:46 PM
Doyle
Jan 22, 2007 10:11 PM
butters417
Mar 22, 2005 02:21 PM
