2015 Ford Edge - o2 sensor issues
Hi all,
I bought a 2015 Ford Edge in January, with only 15,000 miles on it. I looked far and wide for this car, and found the exact one I was looking for.
And then I started having issues. My o2 sensor went out early June, burning through a ton of gas. The dealership fixed it but had no answers about why this happened, but said that it never should have occurred.
Now again, my check engine light is on and Oreillys just ran the code - two
O2 sensors are out, only 2.5 months after the first issue was fixed in June.
I'll call the dealership tomorrow, but I'm curious...is anyone experiencing the same thing? I've been so disappointed throughout all of this, it's taking away from my enjoying a new car!
Thank you,
Kristen
Thank you,
Kristen
Happy New Car !
So you have some idea what may be happening, please keep in mind that there are a minimum of 2 oxygen sensors in your vehicle. Depending on the engine and exhaust system there could be 4. I would think this should all be covered by warranty since they are emission controls.
There could be several possible causes for codes, but it is important to know just what codes were displayed. Aside from the inconvenience , if the car is what you wanted a little patience can go a long way. Sometimes parts can be defective, new technician, intermittent problem are just some of the possible reasons for the problem.
Would you be so kind as to keep us informed as to the work done and what they show on the work order ? It is unusual for problems this early with only 15,000 mi.
Thanks !
Thanks !
fordedge253
Feb 17, 2012 11:07 AM
