2017 Edge Sport tail light replacement
I replaced the passenger side tail light with a used module from a 2017 Titanium edition, the light are stamped with the same numbers, and look identical. The old cracked one works correctly, the new one hyper-flashes the turn signal, all else is normal. Error code B1266-01 right rear turn lamp feedback. Should I assume the light is bad, or can the body computer be reset/reprogramed? Thanks in advance for your time. : )
