Ford Edge 2016 tail light
Old Nov 9, 2016 | 04:16 PM
Sherlock H's Avatar
Default Ford Edge 2016 tail light
Hi everyone
I noticed that the tail light on SEL trim is not as the Titanium .
In the Titanium the whole red line is working unlike the SEL .
Here is a photo of the titanium :
This one is SE but the same on the back with SEL
The question is can I change and make it like the Titanium? because it is way better !
Old Nov 27, 2016 | 05:10 PM
DeplorableClinger's Avatar
Sherlock - I'm just guessing on this but I wouldn't think this can be activated without purchasing the entire light fixture. I'm basing this on the light bar being a non-traditional bulb (i.e. the bar is a continuous LED fixture of unique design; not something that is simply disabled on the SE/SEL models). Check with Ford for an entire rear light assembly but I suspect it's awfully expensive. You might be able to find one from a front end wrecked Edge but that's not very likely.
My only experience with this type of thing goes back to a F150 I purchased new in 2003. It was a "Heritage" edition truck that carried some unique options but not the puddle lamps in the door panels. The lenses were there but they weren't functional (i.e. they didn't light up). A year or so after getting the truck, I broke one of the door panels (long story) but in replacing the panel, I found a wiring harness with an empty plug already installed behind the puddle lamp lens. I figured out what which bulb applied, plugged it in, and bada bing... my puddle lamp light option was suddenly installed.
Apparently Ford built those year trucks with a standard wiring harness that included all the hardware (except the light bulbs). For a mere $150, I could have ordered the "courtesy lamp package" on my new truck but I figured that was a lot of money to get a couple of pretty lights in the door panels. Turns out my cheapness saved me some money and for about $6 and 30 minutes of effort, I had the optional lights that the upgraded trucks had.
That was 13 years ago using traditional incandescent bulbs. The new Edge Titanium lights are significantly more advanced and I suspect, not a shelf item at your local autocrats store.
goodriddance
May 13, 2017 05:05 AM
Jeremy524
Apr 22, 2016 12:38 PM
t0lkman
Feb 29, 2016 07:56 PM
fquattro
Feb 5, 2016 03:45 PM
Drubush
Oct 13, 2014 02:37 AM
