Ford Edge KEY fob stopped working after fob battery replacement
Old Feb 11, 2023 | 12:51 PM
AVAYKTM's Avatar
Default Ford Edge KEY fob stopped working after fob battery replacement
Just replaced the CR2025 battery on ONE of my 2 key fob Push buttons starts and now it doesn't work .. NO lock / unlock / remote start. Has anyone else had this problem with their 2015 Ford Edge? So currently I have only one working Fob...
Also when trying remote start, the key fob blinks 3 times but nothing happens.
And No KEY DETECTED on the dash even when putting the fob into the backup slot inside the center console.
Tried with several different batteries.. no changes
Old Feb 11, 2023 | 02:47 PM
aquanaut20's Avatar
Have found many dead new batteries, double check battery charge and clean contact areas..
Old Feb 11, 2023 | 06:02 PM
AVAYKTM's Avatar
Thanks.. i will try again ..maybe with different brand batteries
Old Feb 12, 2023 | 06:17 AM
When you go to purchase replacement little batteries, read the date on the packaging some are pretty old . They are supposed to be good until a certain date, but that is not always true. You will notice some have been on the shelf for over 5 years.
Old Feb 17, 2023 | 09:09 AM
AVAYKTM's Avatar
Tried everything ...swapping different brand batteries Unfortunately still the same it doesn't even get DETECTED when from the key fob pocket inside the center console...
Time to spend money at the DEALERSHIP
Old Feb 17, 2023 | 09:26 AM
aquanaut20's Avatar
Originally Posted by AVAYKTM
Tried everything
Or, find a local diagnostician
Old Feb 17, 2023 | 09:27 AM
aquanaut20's Avatar
You report 2 fobs,, does the other one still work ?
Old Feb 17, 2023 | 09:30 AM
AVAYKTM's Avatar
Yes, the other FOB still works.. They are both OEM fobs that came with the vehicle.
Old Feb 17, 2023 | 09:55 AM
aquanaut20's Avatar
Then I would try reprogramming the non working fob
Old Feb 17, 2023 | 09:59 AM
AVAYKTM's Avatar
Any recommendation.. is that something is done at the dealership or we can try on our own.
