I need help on my 08 ford edge
Old Sep 2, 2020 | 09:58 PM
Jjrodz93's Avatar
Default I need help on my 08 ford edge
I replaced the tss and oss sensors but now somehow it dont do reverse or forward
Old Sep 2, 2020 | 10:48 PM
scott.butler4's Avatar
Please explain what does this mean? Or if you want you can walk us through what the original issue was, what you did, and what now happens.
"but now somehow it do reverse or forward"
Old Sep 2, 2020 | 11:32 PM
Jjrodz93's Avatar
The gear shift was acting weird so I decide to change them the ford was running good but now since I changed them it dont do reverse or drive
Old Sep 2, 2020 | 11:33 PM
Jjrodz93's Avatar
I dont know if is the valve body or the manual pin
Old Sep 3, 2020 | 07:17 AM
What do you mean by the gear shift was acting weird? Give some actual details if you want good suggestions.
Based on what youve said I am assuming you start the vehicle, you move the gear shift out of park but the trans doesnt change gears and never comes out of park regardless of what you do with the gear shift. Is that correct?
Did you have any codes present before replacing anything?
Do you have any codes after replacing the sensors?
Is the shift lever on the trans tight and correctly attached?
Did you take off the cover assembly to help with getting the TSS wire routed in?
You didnt mess with the range sensor did you?
Normally I would not recommend taking it apart again before some diag but considering it was only "acting weird" till you took the transmission apart and now it doesnt work. I would take it apart again and put it back together very carefully especially paying attention to the make sure the manual pin is correctly installed.
rafeeki
Mar 17, 2016 12:24 PM
trev0006
Nov 20, 2013 01:08 PM
Rvinyl.com
Nov 20, 2013 04:13 AM
bblat1
Dec 20, 2010 03:06 PM
lynnie10
Jun 27, 2010 02:00 PM
