2007 Ford Escape door ajar switch
Old Sep 21, 2019 | 07:13 PM
Laura Gall's Avatar
Default 2007 Ford Escape door ajar switch
Hello, I'm trying to find out how to replace my door ajar switch in my 2007 ford escape XLS. When I look up the videos I can't find anything for my car. I am trying to find out where it is located. I know it is in the door, but where? Could someone please help me.
Thank you
Old Sep 22, 2019 | 12:58 AM
Welcome to the site..
The door ajar switch is located in the door latch.
If the warning lamp wont go out, did you try liberally lubing the latch with a non greasy lube, silicon, graphite based etc, not WD, then rapidly opening/closing the door to see if the switch pintle frees up?
I can send you some illustration on removing the latch if needed...
Old Sep 22, 2019 | 08:00 AM
Laura Gall's Avatar
Yes, I did try spraying it down with lube. It didn't work, if you could send the illustrations, that would be greatly appreciated. I have to try and take the latch out today. I just want to get it fixed.
Old Sep 22, 2019 | 09:21 AM
I emailed some info,
Old Jan 13, 2021 | 12:10 PM
Sonandhis1stcar's Avatar
Ford Fusion 09 plate
sons just bought his first car, sadly the car door open warning lights are staying on and the interior lights
Can anyone recommend a way to over come this please ??
Old Jan 14, 2021 | 05:19 PM
scott.butler4's Avatar
Which door is showing as ajar?
Old Jan 17, 2021 | 03:19 PM
Default Thanks
all of them 🥲
Old Jan 17, 2021 | 06:42 PM
Ok so unless you want to remove all four door panels you are going to need to use a high end scan tool to do a smart junction box(SJB) self test to see which door is reading as ajar.
Your dealer can do this if you pay them, honesly I dont know if non ford scan tools can test this.
Does the vehicle have memory seats or not?
dg7766
Nov 19, 2019 07:01 PM
leatherhead78
Jul 21, 2010 12:28 AM
robinas4
Dec 19, 2008 11:10 AM
labrecque
May 30, 2007 10:52 PM
gdjordahl
Mar 4, 2007 05:52 PM
