Door Ajar
Old Mar 4, 2007 | 12:00 PM
gdjordahl's Avatar
Default Door Ajar
Hello Rangers.......
My '99 Ranger has this thing where sometimes even if I close the door snug, the "Door Ajar" light remians lit and the dome light stays on for awhile, and eventually goes out. I don't see any of those old fashioned door closing contact switches, so how and why does the truck think my door is still open? Is there a relay I need to replace or something? Seems worse in warmer weather....
Thanks,
G
Old Mar 4, 2007 | 01:09 PM
cobra79's Avatar
Default RE: Door Ajar
The switch is located on the door latch. You may try spraying the door latch with wd -40 to see if that will free it up . If it still gives you trouble you will have to remove the inside door panel to replace that switch. You push in and turn to remove switch. good luck
Old Mar 4, 2007 | 05:52 PM
gdjordahl's Avatar
Thanks Cobra79, I'll give it a try.
mike 96 ws6
Sep 25, 2012 08:25 AM
Zapman
Feb 16, 2009 06:29 PM
Mike11C
May 27, 2007 02:14 PM
sshupe
Oct 12, 2005 02:12 PM
sshupe
