2009 ford escape
Old Jun 11, 2019 | 01:05 PM
Dannyk4066's Avatar
Default 2009 ford escape
I have a 2009 Ford Escape with 190000 miles, the vehicle was running fine then it spit out a P 0306 code for a number 6 cyl misfire. Then I found out that the owner had not changed the plugs for 90000 miles. After changing the plugs, the code reader still put out the same code. I then changed the coil, for # 6. Code is still there, is it possible that between the bad plugs and coil caused the ECM to go bad?
Old Dec 3, 2019 | 10:32 AM
Hiedi Wallenmeyer's Avatar
Hook up your OBD reader and clear the code, see if that helps.
Old Dec 3, 2019 | 09:27 PM
09XSCAPE's Avatar
^^^ and if plug wires are original replace.
oldtrumpet
Jan 17, 2016 06:38 PM
charlie.carroll@sbcglobal.net
Mar 3, 2012 05:14 PM
automan1
Jun 26, 2011 09:15 AM
northern1
May 14, 2010 02:30 PM
site2site
Feb 21, 2008 03:18 PM
