Ford Escape turn signal and hazard issues.
Old Dec 8, 2019 | 04:55 PM
RapidDiamond's Avatar
Default Ford Escape turn signal and hazard issues.
Hello all. I was wiring in a new tail light today using the quick connectors. I had everything functioning, brake light, running lights reverse and turn signals. However I think there’s a possibility that an exposed connector touched another and shorted out the system. Because now neither the turn signals, hazards or rear running lights work on either side. Just the reverse and brake lights. I checked the turn signal fuses and they didn’t look broken. Is there a relay or something else I might have fried?? The turn signal icon won’t even pop up on the dash when I turn on the stalk into the left and right positions. Same with hazards.
Old Dec 8, 2019 | 07:12 PM
Welcome to the site
What year Escape?
Old Dec 8, 2019 | 07:19 PM
Welcome to the site
What year Escape?
My apologies, it is an 03.
Old Dec 8, 2019 | 07:53 PM
Double check the fuses, with a test light if possible
Positions,, #6 10amp, #20 15amp, #15 15amp
The cluster signal indicator , gets in power distribution through the flasher module, which would seem there’s a power dropout on one or more of the fuses.
There is a Park Lamp Relay, #15 15amp protects the relay
Old Dec 8, 2019 | 07:55 PM
Okay thanks I will give that a try!
Joebile
Mar 1, 2020 08:56 AM
Cory Revert
Sep 24, 2018 07:56 PM
grandmarquisNM
Jul 21, 2012 10:30 AM
EGamble3
Feb 16, 2009 12:25 PM
cat
Mar 11, 2006 10:57 PM
