View Poll Results: are steering angle sensors an ongoing problem even for those after the recall
continues
0%
resolved
0%
never happened
0%
don't ask
0%
Voters: 0. You may not vote on this poll
2010 Ford Escape Steering
Old Jan 22, 2023 | 05:36 PM
Fox_warren's Avatar
Default 2010 Ford Escape Steering
2010 Ford Escape. 3 Litre awd. It was replaced entirely in march of 2014 under recall. In 2021 I replaced myself the steering angle sensor (I had no shaking) which I bought from Power Steering Seals. Again a year later it has happened again. All fuses to the PCM were checked including the fuses inside the cab. #35 and in the engine compartment A which is an 80 amp. all good. My connections are all very clean. The odd thing is I have no shake or immediate turn to left or right, which was the case in 2021, but armstrong steering. I bought Innova 3160RS which has given me codes (C1963 Stability control Inhibit warning) and of course once again the dreaded 2278.
I also got a code earlier but can't find it again P06B8. Internal control module Non Volatile Random access memory NVRAM error. This code indicates there is a problem with the NVRAM in the PCM.
I have not yet pulled the connections to the PCM itself.
My questions are I have no shimmy or shake. Isn't this supposed to be an almost tell tale sign?
Given its been a year since and it has occurred again. I am leaning towards a fault in the PCM.
What are your thoughts?
Denblake
Sep 19, 2019 09:36 AM
kable
Aug 23, 2019 06:00 PM
landcruizer
Dec 6, 2018 11:05 AM
MatlockPaul
Jan 10, 2015 06:50 AM
banjomax
Nov 30, 2010 01:05 AM
