2014 Escape Low beams on when switch is off and high beams don't come on.
Old May 16, 2023 | 12:01 PM
Cire969's Avatar
Default 2014 Escape Low beams on when switch is off and high beams don't come on.
I have The issue I am having is that the low beams come on when the car is turned on and the light switch is in the off position. I have the dash mounted manual switch. Thus no fog lights and no auto dimming. Also the high beams no longer come on when using the high beam switch. I have looked for codes and the OBDI is not throwing any codes. I was told by a Ford Mechanic that it should be if the switch is bad, however I am not sure if he was just blowing smoke so to speak. I went in the engine fuse box and replace F39 which is the fuse for the Headlight switch. Same result. I then pulled the fuse entirely and still same result the low beams stayed on when the car was on. I replaced the good fuse and removed the light switch. Same results that the low beams stays on when the car was on. I also checked the passenger side fuse for the highbeams and that was ok. I know that if there is a fault with the switch the BCM (Body Control Module) will default to turning on the low beams when it does not know where the switch is. I also tried replacing the switch with a similar switch from my neighbors Escape (although the switch for his had the fog lights and auto dimming so not sure if that would cause the same issue) And nothing changed.
My question is, could there be an issue with the HCM (Headlamp control Module) Would that cause this type of issue? The dealer now wants me to bring it in and them spend hours troubleshooting the wiring but I am not sure that would do anything as there seems to be a fault being read by the BCM as it does not change even when I remove the fuse or the switch itself.
Thanks in advance for any help you might be able to provide.
Old Feb 27, 2026 | 10:31 PM
clahrmer's Avatar
Did you ever get this resolved? I'm experiencing the exact same issue(s). I've tried the fuses just as you have but no luck. Did you figure it out?
Old Feb 28, 2026 | 09:56 AM
Trying to gather some info,,,,,,,,,,,,
Do both your vehicles have daytime running lights ?
Just a little info ,,,,,,,,,both vehicles are OBD II systems.
Old Feb 28, 2026 | 03:23 PM
It's a 2014 Ford, not 1984 (pulling fuses). If you really want to troubleshoot this yourself you need invest and buy a scanner capable to read Ford's specific DTCs. For instance, Foxwell NT510 Elite w/ Ford+Lincoln+Mercury software.
youthpastorrich
Sep 4, 2017 06:13 AM
mem
Oct 26, 2012 04:01 PM
tbirdturbo
Nov 2, 2009 03:28 PM
stuartship
Apr 27, 2008 11:35 AM
broncocarnage
Dec 11, 2007 12:07 PM
