2016 MAP sensor chronically bad
Old Jun 12, 2019 | 09:07 AM
5653rhino's Avatar
Default 2016 MAP sensor chronically bad
In the last 7 months we’ve had check engine light on 6 times. Return to Ford dealer each time. Each time bad MAP sensor code. Last night after a wire overlay from map to pcm car ran 10 miles, had miss fire episode and stalled in the road.Towed back to dealership.Car has 50,160 miles. Ford won’t buy back although same problem reoccurring. We don’t know what to do next.
Old Jun 12, 2019 | 02:06 PM
It is very important to know just what the code(s) were .
It is very unusual for that many sensors to be defective, but anything is possible.. Map sensors report vacuum or intake manifold pressure to the PCM. It does use wiring and electrical signals to do this. There could be a wiring, connection or other related problem in the MAP system , so it is not always the sensor itself.
Have you inquired of the service dept as to why the repeat performance ? Surely you deserve some logical/reasonable explanation..
There could also be an entirely different problem, we don't know this at this time.
Caterpillar man
Jul 10, 2016 08:16 PM
ptclink
Oct 7, 2009 11:43 PM
greuelc
Mar 6, 2009 10:30 PM
00spy
Aug 11, 2007 03:03 PM
mikemac
Dec 13, 2005 11:58 PM
