2017 Escape problems
Old Aug 19, 2020 | 10:56 AM
Dick Vargeson's Avatar
Question 2017 Escape problems
When I put my anylyzer on the codes come back "crankcase pressure", "sensor circuit" I have a problem of a rough start, but only once in a while. It will stall at times, but immediately can be started right back up without any problem and will then run smoothly. I'm not sure what "crankcase pressure " even means. Anyone have a suggestion or better yet an answer?
Old Aug 19, 2020 | 02:06 PM
scott.butler4's Avatar
What engine do you have?
What is the code?
Old Aug 19, 2020 | 03:18 PM
1.5L and I just ran the system again and now it says Cyl 3 misfire. Maybe I need new plugs. I have 67,000 and have never had them changed.
Old Aug 19, 2020 | 07:06 PM
Do a tune up using Motorcraft spark plugs and clear the code to see if it comes out. Other suggestions if the code comes back but don't want to go crazy yet.
Old Apr 2, 2024 | 06:10 PM
Crfarrow's Avatar
Check and see if you are losing coolant, if so you might have a coolant leaking into the cylinder. Is so go to dealer and have them diagnose for coolant consumption.
littleford385
Aug 3, 2020 09:27 PM
copper penny
Apr 19, 2017 08:27 PM
Formathe
Apr 8, 2017 12:40 PM
trev0006
Apr 10, 2012 09:31 PM
fogshat
Apr 21, 2009 11:22 AM
