2019 1.5 escape
Old Mar 17, 2026 | 08:06 PM
jim70dodge's Avatar
Default 2019 1.5 escape
I have a raddle at idle and when ac is on it get louder. when I give it gas the noise goes away.... I have checked the turbo and no problem there. I open the turbo and wast gate and fins are tight. Checked the flex plate by the crank shaft bolt and the fly wheel and everything is tight. please point me in the right direction.
Old Mar 18, 2026 | 11:19 AM
Just in case I did not understand all you stated.
Check the crankshaft pulley itself. the outer part of that pulley is held in place with rubber filling. If that filling has gone away ,it will give notice as you explained and can produce a rattle or knocking at idle.
Have seen this only once, but took a while to find it..
Please let us know what you find, thanks.
shadowspawn
Mar 31, 2025 12:17 PM
F250Project
Jul 2, 2024 08:09 PM
Ryan Lewis
Feb 11, 2020 11:55 AM
Aadd1998
Nov 11, 2014 10:39 PM
D-Bar
Aug 23, 2012 07:25 PM
