Dash brake light
Old Sep 11, 2010 | 05:41 AM
cattceek's Avatar
Angry Dash brake light
I have a 2003 Ford Escape. Had all 4 corners apart replacing wheel bearings. Have fully bled the brake system but the red brake light on the dash won't go out. Is there some kind of resetting that needs to be done?
Old Sep 11, 2010 | 07:29 AM
Sometimes the proportioning valve needs to be recentered. To verify this just unplug the sending unit plug, if the lite goes out , it needs to be recentered. This is usually done by bleeding a little brake fluid from one side or the other in the same manner you normally bleed the brake system. Don't forget the usual stuff, master cyl full etc.
Joe Reeves
May 1, 2014 04:12 PM
mrwhizard
Dec 31, 2013 05:32 PM
kdepq500
Jan 16, 2011 03:46 AM
jenior71
Dec 17, 2008 12:07 AM
tbrooksy
Nov 11, 2005 12:50 AM
